105
Customize Keyboard shortcut from the ribbon customization dialog
In a Windows Form Application, with ribbon, is it possible to customize the keyboard shortcut, defined for a tool, from the ribbon customization dialog, using UltraRibbonCustomizationProvider? Is the only way, call UltraToolbarsManager.Customize ?
  • 1700
    Hello Stefano,
    Yes, you can customize the keyboard shortcut of a tool using the UltraRibbonCustomizationProvider, but the built-in Ribbon Customization dialog does not expose an option for editing keyboard shortcuts directly. The only way to modify keyboard shortcuts programmatically at runtime is to use the UltraToolbarsManager.Customize method.
    This method programmatically allows you to modify keyboard. Example of changing a shortcut for a specific tool:
    var tool = ultraToolbarsManager1.Tools["YourToolKey"] as ButtonTool;
    if (tool != null)
     tool.SharedProps.Shortcut = System.Windows.Forms.Shortcut.CtrlShiftA;
    Please let me know if you need any further assistance.
    Ivan Kitanov
