1375
Regarding validation in grid when using custom combo box
2783.test.zip
Hello sir/mam,
I am facing some issue regarding validation. I have to validate on add/edit that unique combination of location of action and 8d action exists. If user adds it again i need to show a alert combination already exists. But I am confused how to do it.its working when I edit/add and checkbox is unchecked it's not checking when it's a textbox. But when. I check the checkbox and change value then it's working. I need to make it work properly for both add/edit . I am using a map to version map to store already added location and their corresponding 8d action with version number which I update on every save after every edit/add. Could you please help me out with it. I have attached a sample for you to test it.
  • 800
    Hello Rohit,
    I have been looking into your question, and what I can say is that it seems related to the following one here, with the difference that the latter says that only the Add row operation is not working as expected. A possible approach has already been provided there. I will extend the sample a bit so it demonstrates how such a check can be achieved and provide an answer in the other post.
    Also, I noticed that the same question is asked in the following forum post here as well.
    As previously discussed, duplicating your questions across multiple forum posts is not recommended, since it is hard to manage and leads to confusion. Please avoid duplicating your question. This is for better consistency and history tracking.
    An answer to your question can be found here.
    Sincerely,
    Riva Ivanova
    Software Developer
