Louis Garrett
Louis Garrett answered on Feb 25, 2011 10:58 AM
I filled a WebDataGrid with a small SQL Server stored proc result set of 61 rows x 79 varchar(max) columns that took 40 seconds to execute from SQL Server Mgmt Studio.
At first, I got a timeout error on my WebDataGrid page that said, "Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding."
I added this code, which FIXED my TimeOut error:
    <script type="text/javascript" language="javascript">
    function pageLoad()
        var grid = $find("WebDataGrid1");
        grid._callbackManager.setTimeout(60000);
         //All three of these variations produced the same result: Fixed TimeOut Error; Caused null reference error.
         //$find("<%= WebDataGrid1.ClientID%>")._callbackManager.setTimeout(60000);
        //$find("WebDataGrid1")._callbackManager.setTimeout(60000);
    </script>
But now the page throws this error on the .setTimeout line above. "Microsoft JScript runtime error: '_callbackManager' is null or not an object."
My page works properly, with no TimeOut or null reference errors, if I surround the .setTimeout line with try{} and an empty catch{}, as shown in the code below.
Why is _callbackManager null at runtime?
How did this fix my TimeOut Error when _callbackManager was null at runtime?
Thanks.
<%@ Page Title="" Language="C#" MasterPageFile="~/Site.master" AutoEventWireup="true"
    CodeFile="DataPointRatioValue.aspx.cs" Inherits="Grids_DataPointRatioValue" %>
<%@ Register Assembly="Infragistics4.WebUI.WebResizingExtender.v10.3, Version=10.3.20103.2073, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.WebUI" TagPrefix="igui" %>
<%@ Register Assembly="Infragistics4.Web.v10.3, Version=10.3.20103.2073, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.Web.UI.GridControls" TagPrefix="ig" %>
<%@ Register Assembly="Infragistics4.WebUI.WebDataInput.v10.3, Version=10.3.20103.2073, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.WebUI.WebDataInput" TagPrefix="igtxt" %>
    Namespace="Infragistics.Web.UI.ListControls" TagPrefix="ig" %>
<asp:Content ID="Content1" ContentPlaceHolderID="HeadContent" runat="Server">
</asp:Content>
<asp:Content ID="Content2" ContentPlaceHolderID="MainContent" runat="Server">
        function pageLoad()
            try
            catch (e)
                //catch and just suppress error
    </script>
    <table runat="server" cellpadding="5" cellspacing="2">
        <tr>
            <td align="left" colspan="4">
                <asp:Label runat="server" Font-Size="Larger" ID="lblMessage" ForeColor="Maroon"></asp:Label>
            </td>
        </tr>
        <tr>
            <td align="left">
                <ig:WebDropDown ID="ddlDataPointValueSet" runat="server" Width="411px" DropDownContainerWidth="544px"
                    DataKeyFields="DataPointValueSetID" DataSourceID="dSrc_DataPointValueSet" TextField="Name"
                    ValueField="DataPointValueSetID" EnableLoadOnDemand="True" EnableMultipleSelection="True"
                    EnableClosingDropDownOnSelect="False">
                    <DropDownItemBinding TextField="Name" ValueField="DataPointValueSetID" />
                </ig:WebDropDown>
            </td>
            <td align="left">
                <ig:WebDropDown ID="ddlCategory" runat="server" Width="411px" DropDownContainerWidth="544px"
                    DataKeyFields="SubCategoryID" TextField="Category" ValueField="SubCategoryID"
                    EnableLoadOnDemand="True" EnableMultipleSelection="True" DataSourceID="dSrc_Category"
                    <DropDownItemBinding TextField="Category" ValueField="SubCategoryID" />
                </ig:WebDropDown>
            </td>
            <td align="left">
                <igtxt:WebImageButton ID="WebImageButton1" runat="server" Text="Show" AccessKey="w"
                    UnderlineAccessKey="true" OnClick="WebImageButton1_Click" ClickOnEnterKey="true">
                </igtxt:WebImageButton>
            </td>
            <td align="left">
                <igtxt:WebImageButton ID="WebImageButton3" runat="server" Text="Export" AccessKey="x"
                    OnClick="WebImageButton3_Click">
            </td>
        </tr>
    </table>
    <igui:WebResizingExtender ID="WebResizingExtender1" runat="server" TargetControlID="WebDataGrid1" />
    <ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="444px" Width="100%" DataSourceID="dSrc_DataPointRatioValue"
        Visible="False" EnableDataViewState="false">
        <Behaviors>
            <ig:ColumnResizing>
            </ig:ColumnResizing>
            <ig:Filtering>
            </ig:Filtering>
            <ig:VirtualScrolling>
            </ig:VirtualScrolling>
            <ig:Sorting>
            </ig:Sorting>
        </Behaviors>
    </ig:WebDataGrid>
    <ig:WebExcelExporter runat="server" ID="WebExcelExporter1" ExportMode="Download" />
    <asp:SqlDataSource ID="dSrc_DataPointRatioValue" runat="server" ConnectionString="<%$ ConnectionStrings:dbExcelConnectionString %>"
        SelectCommand="usp_Select_Scorecard_Data" SelectCommandType="StoredProcedure">
        <SelectParameters>
            <asp:Parameter Name="DataPointValueSetIDList" Type="String" />
            <asp:Parameter Name="SubCategoryIDList" Type="String" />
        </SelectParameters>
    </asp:SqlDataSource>
    <asp:SqlDataSource ID="dSrc_DataPointValueSet" runat="server" ConnectionString="<%$ ConnectionStrings:dbExcelConnectionString %>"
        SelectCommand="usp_Select_List_DataPoint_Value_Set" SelectCommandType="StoredProcedure">
        <SelectParameters>
            <asp:Parameter DefaultValue="False" Name="AddNullRow" Type="Boolean" />
        </SelectParameters>
    <asp:SqlDataSource ID="dSrc_Category" runat="server" ConnectionString="<%$ ConnectionStrings:dbExcelConnectionString %>"
        SelectCommand="usp_Select_Category" SelectCommandType="StoredProcedure"></asp:SqlDataSource>
</asp:Content>
