IT Department
IT Department answered on Jan 9, 2013 9:35 PM
Using the code you provided the control goes into an infinite loop when this is excuted. I have attached the whole page below. The code behind only sets WebDataGrid1.DataSoure and WebDataGrid1.DataBind()
Please advise. Thanks in advance.
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="TestBed.aspx.cs" Inherits="TTFinancialProjections.TestBed" %>
<%@ Register Assembly="Infragistics35.WebUI.UltraWebCalcManager.v12.2,  Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.WebUI.UltraWebCalcManager" TagPrefix="igcalc" %>
<%@ Register Assembly="Infragistics35.Web.v12.2,  Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.Web.UI" TagPrefix="ig" %>
    Namespace="Infragistics.Web.UI.GridControls" TagPrefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"&gt;
<head runat="server">
    <title>Testbed</title>
       function WebDataGrid_CellEditing_ExitedEditMode(sender, eventArgs) {
            currentrow = eventArgs.getCell().get_row();
            var q1 = currentrow.get_cellByColumnKey("Q1").get_value();
            var q2 = currentrow.get_cellByColumnKey("Q2").get_value();
            var q3 = currentrow.get_cellByColumnKey("Q3").get_value();
            var q4 = currentrow.get_cellByColumnKey("Q4").get_value();
            currentAmount = q1 + q2 + q3 + q4;
            currentrow.get_cellByColumnKey("Total").set_value(currentAmount);
        </script>
</head>
<body>
    <asp:ScriptManager ID="ScriptManager1" runat="server" />
    <div>
        <ig:WebDataGrid ID="WebDataGrid1" runat="server" AutoGenerateColumns="false" ShowFooter="true">
            <Columns>
                <ig:BoundDataField DataFieldName="Id" Key="Id" />
                <ig:BoundDataField DataFieldName="Name" Key="Name" Header-Text="Item" />
                <ig:BoundDataField DataFieldName="Q1" Key="Q1" Header-Text="Q1" />
                <ig:BoundDataField DataFieldName="Q2" Key="Q2" Header-Text="Q2" />
                <ig:BoundDataField DataFieldName="Q3" Key="Q3" Header-Text="Q3" />
                <ig:BoundDataField DataFieldName="Q4" Key="Q4" Header-Text="Q4" />
                <ig:UnboundField Key="Total" Header-Text="Total" />
            </Columns>
            <Behaviors>
                <ig:Activation Enabled="true" />
                <ig:EditingCore BatchUpdating="true" AutoCRUD="true">
                    <Behaviors>
                        <ig:CellEditing Enabled="true" EditModeActions-EnableF2="true" EditModeActions-MouseClick="Single" CellEditingClientEvents-ExitedEditMode="WebDataGrid_CellEditing_ExitedEditMode">
                        </ig:CellEditing>
                    </Behaviors>
                </ig:EditingCore>
                <ig:Selection RowSelectType="Multiple" CellClickAction="Row" Enabled="true" />
                <ig:SummaryRow ShowSummariesButtons="false" FormatString="{1}" AnimationType="Linear" />
            </Behaviors>
            <EditorProviders>
                <ig:NumericEditorProvider />
            </EditorProviders>
        </ig:WebDataGrid>
    </div>
    </form>
</body>
</html>
IT Department
IT Department answered on Dec 7, 2012 7:31 PM
Is there a working example I could see somwhere?  I want the row total to update anytime a cell in that row is changed.
