WebDataGrid with BoundDataField
New DiscussionDears
I have DataTable with tow columns (id,fname) and a WebDataGrid, the code for filling the datatable and the datagrid is:
Dim dd As New test
Dim dt4 As DataTable = dd.DataTable1
dt4.Rows.Add("1", "TestName")
dt4.Rows.Add("2", "TestName2")
WebDataGrid1.DataSource = dt4
WebDataGrid1.DataBind()
everything is working fine, but when I add a BoundDataField with a key named (fname) same as the column's name in the datatable to set some behaviors to the column, so the Asp.net code is:
<ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="400px" >
<Columns>
<ig:BoundDataField DataFieldName="fname" Key="fname">
<Header Text="fname">
</Header>
</ig:BoundDataField>
</Columns>
</ig:WebDataGrid>
so, the DataGrid suppose to bound the BoundDataField into the DataTableColumn which is (fname), but why now I'm getting 2 columns in datagrid? the results I get is:
Sign In
to post a reply
3 Created On
Nov 21, 2019 Last Post
6 years, 3 months ago
