Infragistics Community Forum / Desktop / Ultimate UI for Windows Forms / Trying to select an entire row when a cell is clicked
Graham
Graham asked on Oct 1, 2008 9:27 PM
I’m using this code to select the entire row when a cell is activated by clicking or keyboard
Private Sub ugMain_AfterRowActivate(ByVal sender As Object, ByVal e As System.EventArgs) Handles ugMain.AfterRowActivate
   ugMain.ActiveRow.Selected = True
   Application.DoEvents() ‘ I see the row select
End Sub
This does select the entire row, but another mechanism I am not aware of selects only the cell  Any idea what I am doing wrong??
    [Infragistics] Vince McDonald
    [Infragistics] Vince McDonald answered on Oct 1, 2008 9:18 PM
    With the setup you've provided, the row will be selected as soon as it's activated.  If you click on another cell in the same row, this event won't get raised again – the behavior that occurs then depends on how you've set your grid up.
    If you don't ever need to edit the values in any cell, or to select only individual cells, then you can set the grid's DisplayLayout.Override.CellClickAction to "RowSelect".
    I suggest shying away from calling Application.DoEvents().  It doesn't seem as problematic in CLR 2.0 and CLR 3.5 as it used to be in CLR 1.1, but if you aren't using it for a specific reason, I suggest avoiding it.
      Graham
      Graham answered on Oct 1, 2008 9:27 PM
      ugMain.DisplayLayout.Override.CellClickAction =Infragistics.Win.UltraWinGrid.CellClickAction.RowSelect
      Perfect… Thanks…
Graham
18 years, 1 month ago
Oct 1, 2008 9:27 PM
Feb 24, 2026 9:48 PM
