How To Keep Multiple Grids vertical Scroll Bars In Sync
New DiscussionHi, I’m facing a problem about keeping multiple scroll bars from different grids in sycn.
I have implemented ability that when I expand a row in grid1, the row with same index in other grids will also be expanded. If they do not have child rows, I will change the row spacing after to make the space between the row and next row same as grid 1.
The problem is when I expand a row in grid 1(let’s say this row has 3 child rows), if the row with same index in grid 2 also has 3 child row, then everything goes perfectly. But if there is not child row in grid2, in this case when I slide the scroll bar, the rows in these 2 grids are out of sync. Rows with different index may fall in same line.
Sign In
to post a reply
