Sort a Ultragrid column by numeric value
New Discussionthe datasource for the ultragrid is SQL data rows. one of the columns “SortOrder” is int type in SQL.
when I click on the header of this column, it does the sorting, but it sorts the column treating the numbers as strings. The result is like 1 10 11 12 …..2 20 21…
How do I config the column setting to enable numeric sort?
Thank you,
Sign In
to post a reply
9 Created On
Jun 18, 2013 Last Post
13 years, 1 month ago
