Object Library not Registered
Frank Lin
Frank Lin asked on Oct 1, 2015 9:22 AM
I installed the ActiveThreed Plus 3 on the Windows 7.0 64bit OS. When I open my VB6 project, it shows Object Library not Registered. I tried to manually register the .ocx and it didn’t work. Please advise on how to resolve this problem. Thanks
    Ivaylo Petrov
    Ivaylo Petrov answered on Sep 10, 2015 10:45 AM
    Hi Frank,
    Please try the following approach of registering the .ocx files.
    1. Open the command prompt as Administrator
    2. In order to change the current directory type: cd C:\Windows\sysWOW64\ and press Enter
    3. Type: regtlib *.ocx and press Enter
    Important: Before step 3, make sure to copy the ocx file under C:\Windows\sysWOW64 and replace the asterisk symbol with the name of the file.
      Frank Lin
      Frank Lin answered on Sep 14, 2015 9:36 AM
      I tried above and I am still get the same result. Anything else I can do?
        Ivaylo Petrov
        Ivaylo Petrov answered on Sep 15, 2015 1:06 PM
        Hi Frank,
        This means that your scenario is more complicated that I have expected. As you know Active Thread Plus 3 Components are no longer supported by Infragistics and therefore we can’t assist you further on resolving their compatibility with Windows 7 x64.
        Please see the following link of our supported environments: http://www.infragistics.com/support/supported-environments
        Your issue was referenced to our senior software developers and architects, though. Therefore keep following this forum thread, because if we come up with resolution it will be posted here.
        Frank Lin
        Frank Lin answered on Sep 22, 2015 7:59 AM
        By the way, I download the Activethreed Plus 3 from https://www.infragistics.com/my-account/keys-and-downloads. Do I need to activate it? I tried to activate it with the Suite Unlock and it returns Your suite has not been unlocked. Please advise. Thanks
        Ivaylo Petrov
        Ivaylo Petrov answered on Sep 23, 2015 11:38 AM
        Hi Frank,
        During the installation of Active Threed Plus 3, did you type a valid license key when an appropriate field was prompted?
        Frank Lin
        Frank Lin answered on Sep 24, 2015 12:59 AM
        Yes, I did.
        Ivaylo Petrov
        Ivaylo Petrov answered on Sep 24, 2015 8:53 AM
        Hi Frank,
        One possible reason for an activation screen to pop up is running an application with user who doesn’t have an administrative rights. Therefore please make sure to verify this scenario.
        Frank Lin
        Frank Lin answered on Oct 1, 2015 7:20 AM
        Hi:
        I installed the Activethreed plus with administrator right and I still got the same error message, Object library not registered. I checked the link I cannot get to the first error. Is there another way to verify the license?
        Regards
        Frank
        Ivaylo Petrov
        Ivaylo Petrov answered on Oct 1, 2015 9:22 AM
        Hi Frank,
        While I have been looking for a solution in our forums, I found one thread that could be useful for you.
        It is about registering 16 bit installer of Infragistics COM Components on Windows7 32 bit machine – http://www.infragistics.com/community/forums/p/52530/320151.aspx
        Although this is not exactly your case, the recommended resolutions could be applied in your scenario.
        Let me know if you make some progress on this matter.
Frank Lin
10 years, 12 months ago
Oct 1, 2015 9:22 AM
Feb 19, 2026 2:10 PM
