See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Infragistics.Win.UltraWinGrid.UltraGrid.SynchImeMode(Boolean restoreOnly)
at Infragistics.Win.UltraWinGrid.UltraGrid.OnAfterExitEditMode()
at Infragistics.Win.UltraWinGrid.UltraGrid.FireEvent(GridEventIds id, EventArgs e)
at Infragistics.Win.UltraWinGrid.UltraGridLayout.OnEditorAfterExitEditMode(Object sender, EventArgs e)
at Infragistics.Win.EmbeddableEditorBase.OnAfterExitEditMode()
at Infragistics.Win.EmbeddableEditorBase.ExitEditMode(Boolean forceExit, Boolean applyChanges)
at Infragistics.Win.UltraWinGrid.UltraGridCell.ExitEditMode(Boolean cancellingEditOperation, Boolean forceExit)
at Infragistics.Win.UltraWinGrid.UltraGridCell.ExitEditMode()
at Infragistics.Win.UltraWinGrid.UltraGrid.ClearActiveCell(Boolean invalidate, Boolean shutdown)
at Infragistics.Win.UltraWinGrid.UltraGrid.set_ActiveCell(UltraGridCell value)
at Infragistics.Win.UltraWinGrid.UltraGridRow.Activate()
at Infragistics.Win.UltraWinGrid.UltraGridRow.SetFocusAndActivate(Boolean byMouse, Boolean enterEditMode, Boolean byTabKey)
at Infragistics.Win.UltraWinGrid.UltraGridRow.SetFocusAndActivate()
at Infragistics.Win.UltraWinGrid.UltraGrid.Infragistics.Win.ISelectionManager.ActivateItem(ISelectableItem item)
at Infragistics.Win.SelectionStrategyExtended.OnMouseDown(ISelectableItem item, MouseMessageInfo& msginfo, Boolean forceDrag)
at Infragistics.Win.SelectionStrategyExtended.OnMouseDown(ISelectableItem item, MouseMessageInfo& msginfo)
at Infragistics.Win.SelectionStrategyExtended.OnMouseMessage(ISelectableItem item, MouseMessageInfo& msginfo)
at Infragistics.Win.ControlUIElementBase.ProcessMouseDownHelper(Object sender, MouseEventArgs e)
at Infragistics.Win.ControlUIElementBase.ProcessMouseDown(Object sender, MouseEventArgs e)
at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
at Infragistics.Win.UltraWinGrid.UltraGrid.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1080.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Microsoft.VisualStudio.HostingProcess.Utilities
Assembly Version: 14.0.0.0
Win32 Version: 14.0.23107.0
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities/14.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.dll
Win32 Version: 4.6.1038.0 built by: NETFXREL2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Microsoft.VisualStudio.HostingProcess.Utilities.Sync
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities.Sync/14.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll
System
Win32 Version: 4.6.1081.0 built by: NETFXREL3STAGE
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/Syst
