Infragistics Community Forum / Web / Ignite UI for Angular / Issue while compilation with angular 8
Suprasanna Ojha
Suprasanna Ojha asked on Jul 3, 2019 7:27 AM
ERROR in ./src/styles.scss (./node_modules/@angular-devkit/build-angular/src/angular-cli-files/plugins/raw-css-loader.js!./node_modules/postcss-loader/src??embedded!./node_modules/sass-loader/lib/loader.js??ref–13-3!./src/styles.scss)Module build failed (from ./node_modules/sass-loader/lib/loader.js):
‘#{map-get(_l1-shadows($l1-color), $elevation)}, ^ Expected ‘. ╷114 │ ‘#{map-get(_l1-shadows($l1-color), $elevation)}, │ ^ ╵ node_modules/igniteui-angular/lib/core/styles/base/elevations/_index.scss 114:57 root stylesheet node_modules/igniteui-angular/lib/core/styles/base/_index.scss 5:9 @import node_modules/igniteui-angular/lib/core/styles/themes/_utilities.scss 1:9 @import node_modules/igniteui-angular/lib/core/styles/themes/_core.scss 10:9 @import node_modules/igniteui-angular/lib/core/styles/themes/_index.scss 7:9 @import stdin 4:9 root stylesheet in /Users/suprasanna/workspace/angular8-starter/node_modules/igniteui-angular/lib/core/styles/base/elevations/_index.scss (line 114, column 57)[emoticon:9c6076b24f9a4273827ce75531b6bf77] 「wdm」: Failed to compile.
    Martin Pavlov
    Martin Pavlov answered on Jun 17, 2019 11:27 AM
    Hello Suprasanna,
    I believe the same issue is discussed here: https://github.com/IgniteUI/igniteui-angular/issues/5077. You can subscribe to the issue in GitHub to get notifications.
    Martin Pavlov
    Martin Pavlov
    Martin Pavlov answered on Jul 3, 2019 7:27 AM
    Hello Suprasanna,
    Let me know if you still need assistance regarding this issue.
    Martin Pavlov
Suprasanna Ojha
7 years, 1 month ago
Jul 3, 2019 7:27 AM
Mar 5, 2026 12:24 PM
