Infragistics Community Forum / Web / Ignite UI for Angular / On click on grid's cell need to select only clicked cell, not entire row
Andrew A
Andrew A asked on Jul 3, 2020 8:47 AM
On click on grid’s cell the entire row of the grid (with clicked cell) is selected completely.
But I need to select only the clicked cell, row must be stay unselected. How to achieve this?
Here is my grid
 <igx-grid igxPreventDocumentScroll #grid1 [data]="data"
    [width]="'100%'" [height]="'100%'"
    [autoGenerate]="false"
    [displayDensity]="'cosy'"
    [rowSelection]="'single'"
    [columnHiding]="true"
    [primaryKey]="'id'"
    paste-handler (onDataProcessed)="dataPasted($event)"
    (onFilteringDone)="filteringDone($event)"
    (onSortingDone)="sortingDone($event)">
</igx-grid>
    Teodosia Hristodorova
    Teodosia Hristodorova answered on Jul 3, 2020 6:58 AM
    Thank you for the provided code snippet. It helped me a lot.
    My suggestion  for achieving your requirement is setting the rowSelection to none
    [rowSelection]="'none'"
    Alternatively,  you could remove it since none is the default value for the rowSelection input.
    Here could be found a sample application that demonstrates this behavior. Please test it on your side and let me know if I may be of any further assistance.
      Andrew A
      Andrew A answered on Jul 3, 2020 8:19 AM
      Hello, Teodosia. Thanks for reply. I need [rowSelection]=”‘multiple”, not even “single” – as mentioned in my question.
      So far I have managed to achieve this goal only with adding of boolean flag for “cell-Selected” event in my js code and checking it in “onRowSelectionChange” handler.
      <igx-grid
      (onSelection)=”onCellSelection($event)”
      (onRowSelectionChange)=”onRowSelectionChange($event)”>
      </igx-grid>
      js code:
      cellSelected : boolean = false;
      public onCellSelection(event) {
          this.cellSelected = true;
      public onRowSelectionChange(event) {
          if (this.cellSelected){
             event.cancel = true;
             this.cellSelected = false;
      It looks quite ugly, of course. Would be nice to get the same result by adjustment of some grid settings.
      Is it possible?
        Teodosia Hristodorova answered on Jul 3, 2020 8:47 AM
        By design selection feature provides either row or cell selection and the described behavior should be achieved manually, as in your approach by handling igx-grid events. Having this in mind, your workaround in this case looks good.
Andrew A
6 years, 1 month ago
Jul 3, 2020 8:47 AM
Feb 23, 2026 11:48 AM
