IgniteUI igDataChart updating series datasource in javascript dynamically
New DiscussionHi,
I followed the given steps in (https://pt-br.infragistics.com/community/forums/f/ignite-ui-for-jquery/121293/adding-series-dynamically-to-igdatachart-and-assigning-data0 in order to add dynamically new series to igDataChart.
As a summary, my JavaScript code for initializing chart is a follows:
function initializeDataChart() {
$("#chart").igDataChart({
isHorizontalZoomEnabled: true,
isVerticalZoomEnabled: true,
windowResponse: "immediate",
width: "100%",
axes: [
type: "numericX",
stroke: "black",
strokeThickness: 1,
LabelTopMargin: 10,
labelAngle: 0,
labelExtent: 50,
formatLabel: function (item) {
var date = new Date(item);
return date.toLocaleString();
type: "numericY",
stroke: "black",
strokeThickness: 1,
majorStroke: "lightGrey",
labelExtent: 50,
return item.toFixed(2);
and for creating new series:
createSeries(deviceName, devicePoints);
series: series,
function createSeries(deviceName, points) {
var s1 = {
type: "scatterLine",
markerType: "circle",
thickness: 1,
tooltipTemplate: "tooltipTemplate",
xAxis: "xAxis",
yAxis: "yAxis",
xMemberPath: "TimeStampTotalMillisecond",
yMemberPath: "Value",
trendLineThickness: 3,
showTooltip: true,
title: deviceName,
dataSource: points,
legend: { element: "legend" }
series.push(s1);
Now, I want to clear series completely preparing to the next data by using the following code, but cannot delete current series data and still see it in igDataChart:
function clearDataChartFunction() {
var chartCurrentSeries = $("#chart").igDataChart("option", "series");
var arrayLength = chartCurrentSeries.length;
for (var i = 0; i < arrayLength; i++) {
chartCurrentSeries[i].dataSource = [];
$("#chart").igDataChart("notifyVisualPropertiesChanged", chartCurrentSeries[i].name);
series = [];
series: series
$("#chart").igDataChart("renderSeries", "xAxis", true);
- What is the correct way to clear igDataChart in my situation?
- Is there any method to call that would enforce rendering igDataChart?
- Which event(s) are triggered after loading data in igDataChart?
Best regards.
Sign In
to post a reply
5 Created On
Jun 02, 2021 Last Post
5 years, 3 months ago
