Infragistics Community Forum / Web / Ignite UI for jQuery / Style igGrid Rows and Cells Based on Data Validation
Guruprasad Srinivasamurthy
Guruprasad Srinivasamurthy asked on Dec 24, 2018 11:07 AM
HI,
I have a grid with data. I also have a button called ‘Validate’. I’m trying to implement a logic such that when I click on the validate button, it goes through all the row data and highlights the row based on the data it contains (For Eg: Highlight the row if the data on a column is missing). I have a function like this, but the row doesn’t seem to get highlighted. Please help.
$(“#validate”).on(‘igbuttonclick’, function (e)
var rows = grid.igGrid(“allRows”);
var dataField1,dataField2;
$.each(rows, function (index, row) {
rowId = $(row).attr(“data-id”)
dataField1 = grid.igGrid(“getCellValue”, rowId, “DataField1”);
if (dataField1 == “Val1”)
dataField2=grid.igGrid(“getCellValue”, rowId, “DataField2”);
if ( dataField2== “”)
$(“#invGrid”).igGrid(“cellById”, rowId, “DataField2”).addClass(“errorHighlight”);
Here, I’ve tried a cell highlight which is jot working. A row highlight will also help me.
Guru
    Vasil Pavlov
    Vasil Pavlov answered on Feb 1, 2018 4:32 PM
    Hello Guruprasad,
    You could iterate over the rows and cells of the grid in the validation button’s “click” event handler. Write a filter function to return “true” or “false” if the cell passes the conditions you want. Then add the necessary CSS to highlight the invalid rows. See the code sample I provided below:
        Sample
    Note that iterating over a very large dataSource could be resource consuming and slow down the browser’s performance. For such cases I suggest that you use the igValidator control and validate cells during editing.
    Vasil Pavlov
      Guruprasad Srinivasamurthy answered on Feb 5, 2018 10:14 PM
      HI Vasil,
      Thanks for the example:). Can I know how I can code for the 'EditRowEnded' event in the razor page rather than script?
      Guru
        Vasil Pavlov
        Vasil Pavlov answered on Feb 6, 2018 12:54 PM
        Hello Guru,
        If you have an MVC scenario, there are two ways to add the event handler:
        1. You could delegate the event directly in your View using for instance the following code, inside a <script> tag:
        $(document).on("iggridupdatingeditrowended", "#igGrid", function (evt, ui) {
        ….some code…..
        1. If you are using a GridModel class to create your grid, then you can define the event with the following code:
        GridUpdating updating = new GridUpdating();
        updating.EditMode = GridEditMode.Row;
        updating.AddClientEvent("editRowEnded", "rowEditHandler");
        gridModel.Features.Add(updating);
        After that you have to declare the handler itself. You could write it in the View (again inside a <script> tag):
        function rowEditHandler(evt, ui) {
        …..some code….
        Vasil Pavlov
8 years ago
Feb 12, 2026 9:23 AM
