how to iterate WebDataGrid Rows
Gabriel
Gabriel asked on Jan 31, 2014 5:44 PM
Hi, for UltraWebGrids I used the next code to iterate the ultrawebgrid rows.
                foreach (Infragistics.WebUI.UltraWebGrid.UltraGridRow SRC in this.WebDataGridGastosProp.Behaviors.Selection.SelectedRows)
                    BE.GastosParticulares unGasto = new BE.GastosParticulares();
                    unGasto.Codigo = int.Parse(SRC.Cells[0].Text.ToString());
                    unGasto.Importe = decimal.Parse(SRC.Cells[5].Text.ToString());
                    lista.Add(unGasto);
But which would be the equivalent on WebDataGrid ?
Thanks!
Regards.
    [Infragistics] Petar Ivanov
    [Infragistics] Petar Ivanov answered on Oct 26, 2011 8:29 AM
    Hi gabrieler,
    In order to iterate through WebDataGrid's rows you should be able to use something like:
            foreach (GridRecord row in WebDataGrid1.Behaviors.Selection.SelectedRows.Count)
                var a = row.Items[0].ToString();
                var b = row.Items.FindItemByKey("ColKey").ToString();
    Petar Ivanov
    Developer Support Engineer
      [Infragistics] Petar Ivanov answered on Oct 31, 2011 7:54 AM
      Hi gabrieler,
      Please let me know if you need further assistance with this matter.
      Petar Ivanov
      ross
      ross answered on Dec 15, 2013 9:37 PM
      How does this work in IG 2012.2? IE…. GridRecord is not in the namespace
      Infragistics.WebUI.UltraWebGrid.UltraGridRow GridRecord
      How do you do this in version 2012.2?
        [Infragistics] Petar Ivanov answered on Dec 16, 2013 8:11 AM
        Hello rookertrusted,
        The GridRecord class is part of the Infragisitcs.Web.UI.GridControls Namespace in the Infragistics.Web Assembly:
        http://help.infragistics.com/Doc/ASPNET/2013.2/CLR4.0/?page=Infragistics4.Web.v13.2~Infragistics.Web.UI.GridControls.GridRecord.html
        GridRecords are used by the WebDataGrid control which is different than the UltraWebGrid. Please note that since version 11.2, the UltraWebGrid has been retired as is no longer available.
        Hope this helps. Please do not hesitate to contact me if you have any questions.
    Uchiha  Itachi
    Uchiha Itachi answered on Jan 10, 2014 3:41 AM
    It happens that I got a parallel question on the row iterating. Fortunate to see the problem solved.
      Michael
      Michael answered on Jan 31, 2014 5:44 PM
      Sometimes you guys make basic stuff way too difficult. You also forget about the people coding in VB
      Here is a very easy Webdatagrid iteration through all rows in VB:
      Dim iSelectedCount As Integer = 0
      For index = 0 To WebDataGrid1.Rows.Count – 1
      If WebDataGrid1.Rows.Item(index).Items(3).Value = True Then
                      iSelectedCount += 1
      End If
      Next
      In this case Items(3) is a boolean or bit field and I am checking to see if it is checked
Gabriel
12 years, 1 month ago
