Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / get selected row index in webdatagrid
xinde
xinde asked on Dec 5, 2012 12:31 PM
I have trouble to get selected row index in webdatagrid.  here is the code:
function WebDataGridView_CellSelectionChanged(webDataGrid, evntArgs) {
var grid = $find(“<%=WebDataGrid1.ClientID%>”);
var rows = grid.get_rows();
var row = rows.get_row(1); // 1 = your row index
var cellValue = row.get_cell(1).get_value(); // 0 = your cell index
alert(cellValue);
The above code works. But I want to get the selected row index. So I use the following code:
var newSelectedCell = eventArgs.getSelectedCells().getItem(0);
var row = newSelectedCell.get_row();
var rowIndex = row.get_index();
However, I get error. Can you please help me to get the selected row index. Thanks.
    Edward
    Edward answered on Mar 27, 2011 2:49 AM
    Once you have the row you can use:
    gridrow._index
    Ed
      xinde
      xinde answered on Mar 27, 2011 3:24 PM
      Thanks for help. I don't have row. but I have the rows by using grid object. I try to get the selected index to get that selected row.
      I used ultraGrid before. The way to get it is:
      var row = igtbl_getRowById(cellID);
      I don't know get the selected row in webdatagrid.
        Edward
        Edward answered on Mar 27, 2011 3:39 PM
        After the line:
        you then have the row. Then you can use:
        row._index
        to get the index of that row.
        Ed
        Abhishek
        Abhishek answered on Sep 17, 2011 11:07 PM
        Hi , Following code can help in getting the Current selected Row Index in Server Side
        string currentRowIndex = this.WebDataGrid1.Behaviors.Activation.ActiveCell.Row.Index.ToString();
        Abhishek
    Aparna
    Aparna answered on Dec 5, 2012 12:31 PM
    I had the same problem. On row selection I wanted the row index. The solution I found out is like this –
    eventArgs.getSelectedRows()._keys.length – 1].index
    here length – 1 because the keys array stores all the selected row indices in case you have allow multiple select = true. So length – 1 will give the latest selected row index.
xinde
13 years, 11 months ago
Feb 18, 2026 2:24 PM
