Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / How to disable paging in order to export data from webdatagrid to excel?
Jdag
Jdag asked on Oct 6, 2023 1:23 PM
I  have paging enabled and I cannot export the entire data to excel
export button:
<img src=”../images/i_exportXLS.png” />
<asp:Button ID=”btnExport” runat=”server” Text=”Export to Excel” class=”button” Width=”140″
OnClick=”btnExport_Click” />
<ig:WebExcelExporter ID=”exporter” runat=”server”
</ig:WebExcelExporter>
paging:
<ig:Paging PageSize=”100″ Enabled=”true” PagingClientEvents-PageIndexChanging=”batchUpdateAlert” PagerAppearance=”Both” >
<PagingClientEvents PageIndexChanging =”batchUpdateAlert” />
</ig:Paging>
server side export function:
protected void btnExport_Click(object sender, EventArgs e)
try
if (wdgModifyPositions.Rows.Count >= 1)
this.exporter.Export(this.wdgModifyPositions);
lblError.Visible = false;
AlertPic.Visible = false;
else
lblError.Text = “Please Load Data into the Data Grid”;
lblError.Visible = true;
AlertPic.Visible = true;
catch (Exception ex)
ErrorHandle.ExceptionHelper(ex);
I saw the examples on forum for ultragrid :
 UWGrid.DisplayLayout.Pager.AllowPaging = False
and this does not work on webdatagrid. What is possible way to disable paging on webdatagrid??
Thanks!!
    Divya Jain
    Divya Jain answered on May 12, 2016 8:48 PM
    Hello Jdag,
    To get entire data to excel sheet while exporting the grid I would recommend instead of disable paging use DataExportMode property in the WebExcelExporter. DataExportMode determines whether the grid will export the entire set of data.
    In the markup add the property as :
    <ig:WebExcelExporter ID="WebExcelExporter11" DataExportMode ="AllDataInDataSource" runat="server"  />
    You can refer the following API link, list all the member exposed by exporter.
    http://help.infragistics.com/doc/ASPNET/2015.2/CLR4.0/?page=Infragistics4.Web.v15.2~Infragistics.Web.UI.GridControls.BaseExporter_members.html
    Please let me know if I may be further assistance.
      Jdag
      Jdag answered on May 12, 2016 9:14 PM
      Hi Divya,
      Thank you I try to implement like that in future. For now I did following:
      try
      //disable paging before exporting
      this.wdgModifyPositions.Behaviors.Paging.Enabled= false;
      this.wdgModifyPositions.DataBind();
      //export data
      //enable paging
      this.wdgModifyPositions.Behaviors.Paging.Enabled = true;
      this.wdgModifyPositions.DataBind();}
      I wanted to know how can I append date to download file name. Currently I am using downloadName
      <ig:WebExcelExporter ID="exporter" runat="server" DownloadName="ModifyPositions"  >
      I would like file name be like ModifyPositioons20161205.xls
      I  tried following but it does not work:
      try
      //export data
      //enable paging
      string FileName = HttpUtility.UrlEncode("ModifyPositions" + DateTime.Now.ToString());
      Response.Clear();
      Response.AddHeader("content-disposition", "attachment; filename=" +FileName);
      Response.ContentType = "application/vnd.xls";
      System.IO.StringWriter WriteItem = new System.IO.StringWriter();
      System.Web.UI.HtmlTextWriter htmlText = new HtmlTextWriter(WriteItem);
      wdgModifyPositions.RenderControl(htmlText);
      Response.Write(WriteItem.ToString());
      Response.End();
      this.exporter.DownloadName = FileName;
      else
      lblError.Text = "Please Load Data into the Data Grid";
        Divya Jain
        Divya Jain answered on May 13, 2016 9:18 PM
        Hello Jdag,
        To append date to download file name while exporting file in excel format, you have to append date in the file name and then replace “/” character as:
        string fileName = "ModifyPositioons" + DateTime.Now.ToShortDateString();
                fileName = fileName.Replace("/", "");
        The reason this is happening is because the “/” character is not allowed to be in file names. So you have to convert it to something that is allowed. Note IE does this by default and converts the “/” to underscores “_”. Chrome doesn’t seem to do this and instead converts it to “%20”.
        I have created a sample project find the attachment.
        Please let me know if you have any further questions concerning this matter.
      Maurizio Bonettini
      Maurizio Bonettini answered on Oct 6, 2023 1:23 PM
      Dear Sirs, i have a similar problem but i can't solve with the DataExportMode as DataInGridOnly because i need to export from a filtered Datasource.
      I try to explain better: in my page i'm using a WebHierarchicalDataGrid with Filtering and Paging Behaviors enabled, and (i think) that's the problem!
      By now, It's impossibile to export all data when a customer use the filter for any column (and the data are in more than 1 page).
      I can export each page by time.. but you can understand that's not a real solution.
      I tryied also the Divya solution but i receive the Exception Thread.Ended:
      Try
                  WebHierarchicalDataGrid1.Behaviors.Paging.Enabled = False
                  WebHierarchicalDataGrid1.DataBind()
                  WebExcelExporter1.DownloadName = "ElencoMRP_Filtrato"
                  WebExcelExporter1.DataExportMode = DataExportMode.DataInGridOnly 'DataExportMode.AllDataInDataSource
                  WebExcelExporter1.Export(WebHierarchicalDataGrid1)
                  WebHierarchicalDataGrid1.Behaviors.Paging.Enabled = True
              Catch ex As Exception
                  Console.WriteLine(ex.Message)
      End Try
      Could you please help me?
Jdag
2 years, 11 months ago
Oct 6, 2023 1:23 PM
Feb 23, 2026 10:29 AM
