Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / DropDown returns only System.Data.dataRowview
A
A asked on May 8, 2012 1:38 PM
When I bind the DropDown on the codebehind, the Dropdown populates with
System.Data.DataRowView for as many records as there are.
Why is the actual data not being populated?
Mark up is as follows
ig:WebDropdown ID="ddlSearch" runat="server" Visible="False" AutoPostBack="True" DropDownContainerHeight="0px" EnableAutoFiltering="Server" EnableLoadOnDemand="True"><AutoPostBackFlags SelectionChanged="On" ValueChanged="On" /></ig:WebDropdown>
My code in behind is as follows
Dim sqlConn As SqlConnection
Dim comm As SqlCommand
Dim da As SqlDataAdapter
Dim ds As New DataSet
sqlConn = New SqlConnection(System.Configuration.ConfigurationManager.ConnectionStrings("ConnectionString").ConnectionString)
Try
comm = New SqlCommand("SELECT Col1 FROM XYZ", sqlConn)
comm.CommandType =
CommandType.Text
sqlConn.Open()
comm.ExecuteNonQuery()
da =
New SqlDataAdapter(comm)
da.Fill(ds)
da.Dispose()
For i As Integer = 0 To ds.Tables(0).Rows.Count – 1
ddlSearchShip.DataSource = ds
ddlSearchShip.DataBind()
ddlSearchShip.TextField =
"Col1"
Next
Catch ex As Exception
Response.Write(ex)
End Try
sqlConn.Close()
sqlConn.Dispose()
    [Infragistics] Surya
    [Infragistics] Surya answered on May 3, 2012 9:41 PM
    Hello Svasala,
    Thank you for posting your question to Infragistics forums.
    From the code you have provided, I see that you are not binding the data to right WebDropDown. The ID of the WebDropDown in the markup is “ddlsearch” and in the codebehind is “ddlsearchship”. Change the “ddlsearchship” to ddlsearch and it should work.
    Prabha
      [Infragistics] Surya answered on May 8, 2012 1:38 PM
      Hello Svasala,
      Please let me know if I can provide any further assistance regarding this matter.
A
13 years, 10 months ago
A
May 8, 2012 1:38 PM
May 8, 2012 1:38 PM
