Infragistics Community Forum / Web / Ignite UI for Angular / any component is not a known element.
Sam Kumar
Sam Kumar asked on Apr 13, 2020 1:42 PM
I’m adding infragistics angular ui to an existing angular application. I get this error: ‘igx-drop-down’ is not a known element:
I followed the steps mentioned here: https://pt-br.infragistics.com/community/blogs/b/infragistics/posts/step-by-step-with-images-to-add-ignite-ui-for-angular-in-an-existing-angular-project
In package.json:
“igniteui-angular”: “^9.0.9”,
“igniteui-angular-charts”: “^9.0.1”,
“igniteui-angular-core”: “^9.0.1”,
“igniteui-angular-maps”: “^9.0.1”,
app.module.ts:
import {
IgxAutocompleteModule,
IgxButtonModule,
IgxDropDownModule,
IgxInputGroupModule,
IgxDatePickerModule,
IgxDialogModule,
IgxIconModule,
IgxSelectModule,
IgxTimePickerModule
} from ‘igniteui-angular’;
In Imports:
IgxButtonModule,
IgxDropDownModule,
IgxDialogModule,
IgxIconModule,
IgxSelectModule,
IgxTimePickerModule,
In component:
<igx-drop-down #cinemaPanelmaxHeight=”350px”>
<igx-drop-down-item-group *ngFor=”let town of towns | groupContains: cinema.value” [label]=”town.name”>
<igx-drop-down-item *ngFor=”let cinema of town.cinemas | contains: cinema.value” [value]=”cinema”>
{{cinema}}
</igx-drop-down-item>
</igx-drop-down-item-group>
</igx-drop-down>
Error:
<igx-drop-down #cinemaPanel maxHeight=”350px”> [ERROR ->]<igx-drop-down-item-group *ngFor=”let town of towns | groupContains: cinema.value” [label]=”town.name”) ‘igx-drop-down’ is not a known element: 1. If ‘igx-drop-down’ is an Angular component, then verify that it is part of this module. 2. If ‘igx-drop-down’ is a Web Component then add ‘CUSTOM_ELEMENTS_SCHEMA’ to the ‘@NgModule.schemas’ of this component to suppress this message. (” </mat-form-field>
    Martin Evtimov
    Martin Evtimov answered on Apr 13, 2020 10:50 AM
    Hello Sam,
    The tutorial you are referring to is a bit outdated. There is a new easier way of adding Ignite UI for Angular to an existing project. I suggest you to take a look at the following topics in our official documentation:
    Installing and Creating a Project
    Installing Ignite UI for Angular
    As I have seen, you are trying to use our dropdown component. Here you can find documentation about it as well. I hope that with help of those three topics you will be able to resolve the error you are facing.
    Martin Evtimov
      Sam Kumar
      Sam Kumar answered on Apr 13, 2020 12:50 PM
      Hi Martin,
      Thanks for your response. I was able to fix the issue.
      The component in which I was using igx-drop-down was declared in a shared module. I declared IgxDropDownModule import in the shared module and the igx component works fine.
      Sam
        Martin Evtimov
        Martin Evtimov answered on Apr 13, 2020 1:42 PM
        Hello Sam,
        I am glad that you managed to achieve your requirement.
        Martin Evtimov
Sam Kumar
5 years, 10 months ago
Feb 12, 2026 10:05 AM
