Infragistics Community Forum / Cross Platform / Ultimate UI for Xamarin / Changing the Column Width from code behind
Rajiv
Rajiv asked on Sep 26, 2016 9:13 AM
I have a requirement where I need to set the width of a column to "Auto". I am able to do this from XAML code but couldn't find a way to set it from code behind.
Though, I am aware that to change the width I can use – column.Width = new ColumnWidth(3.5, true);
but with this approach I am not sure if the width can be set to "Auto".
Any suggestions on this is appreciated.
Thank You,
Raj
    [Infragistics]Tacho
    [Infragistics]Tacho answered on Sep 21, 2016 8:46 AM
    Hello Raj,
    In order to set the width of a column in XamGrid to Auto in code-behind, you can set the Width property of the respective column to ColumnWidthType.InitialAuto or ColumnWidthType.Auto.
    Code-behind:
    xamGrid.ColumnWidth = ColumnWidthType.InitialAuto;
    For more detailed information, you can take a look at Change Column Width Settings.
      Rajiv
      Rajiv answered on Sep 21, 2016 9:09 AM
      Hi Tacho,
      The ColumnWidth property mentioned above is available at the XAMGrid level and I don't see it at the column level. My requirement is to set the width of specific column(s) to "Auto".
      Raj
        [Infragistics]Tacho
        [Infragistics]Tacho answered on Sep 21, 2016 11:27 AM
        Hello Raj,
        Setting a specific width to any of the Columns can be done by casting the column to it's actual type and setting it's Width property respectively.
        For example:
        (grid.Columns[0] as TextColumn).Width = ColumnWidth.Star;
        (grid.Columns[1] as TextColumn).Width = ColumnWidth.Auto;
        (grid.Columns[2] as TextColumn).Width = new ColumnWidth(60, false);
        Rajiv
        Rajiv answered on Sep 21, 2016 5:02 PM
        Thank You, Tacho. Worked for me.
        [Infragistics]Tacho
        [Infragistics]Tacho answered on Sep 26, 2016 9:13 AM
        Hello Raj,
        Thank you for your feedback.
        I am glad to know that I was able to help you achieve the functionality you were looking for. I believe this thread can help other people looking for a similar solution.
Rajiv
9 years, 6 months ago
