Cant use moving grid
Programmeer Meneer Customer
Programmeer Meneer Customer asked on Sep 26, 2022 9:56 AM
ERROR
src/app/hpt/ui-components/week-grid/week-grid.component.html:19:11 - error NG8002: Can't bind to 'moving' since it isn't a known property of 'igx-grid'.
1. If 'igx-grid' is an Angular component and it has 'moving' input, then verify that it is part of this module.
2. If 'igx-grid' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
3. To allow any property add 'NO_ERRORS_SCHEMA' to the '@NgModule.schemas' of this component.
19           [moving]="true"
  src/app/hpt/ui-components/week-grid/week-grid.component.ts:27:16
    27   templateUrl: './week-grid.component.html',
    Error occurs in the template of component WeekGridComponent.
    Bozhidara Pachilova
    Bozhidara Pachilova answered on Sep 26, 2022 9:56 AM
    Similar errors are usually thrown when the related modules are not added to the parent module’s ‘imports’ array. For the grid column reordering & moving functionality to work, no particular module is needed, though, except for obviously the IgxGridModule.
    Please, make sure the following is added to your App module, or parent feature module of the target component, for example:
    import {         IgxGridModule,} from "igniteui-angular";
    @NgModule({
      bootstrap: [AppComponent],
      declarations: [
    	AppComponent,
    	/*etc.*/
      imports: [
    	BrowserModule,
    	BrowserAnimationsModule,
    	FormsModule,
    	IgxGridModule
      providers: [],
      entryComponents: [],
      schemas: []
    export class AppModule {}
    Bozhidara Pachilova
3 years, 5 months ago
