Infragistics Community Forum / Web / Ignite UI for Angular / Cannot find module 'igniteui-angular'
Gautam Singh
Gautam Singh asked on Jun 30, 2020 1:46 PM
i am getting Cannot find module ‘igniteui-angular’ after upgrading to licensed version.
followed the steps given here
https://pt-br.infragistics.com/products/ignite-ui-angular/angular/components/general/ignite-ui-licensing.html
Visual studio code is not showing any error. but while using ng serve error is thrown.
    Teodosia Hristodorova
    Teodosia Hristodorova answered on Jun 30, 2020 1:46 PM
    Thank you for the provided screenshots. In case the update and licensing are successful the module should be changed to  '@infragistics/igniteui-angular'  instead of 'igniteui-angular'.
    My suggestion in order to resolve this issue is to follow the steps below:
    1. Run npm uninstall igniteui-angular and delete the ignite-ui-cli.json file in case you have such a file already generated.
    2. Make sure that the  igniteui-angular": "^9.1.0" is deleted from the package.json file
    3. Run ng add igniteui-angular
    4. Run ng g @igniteui/angular-schematics:upgrade-packages
    5. You should be asked to log in and in case the entered credentials are correct the packages should be installed successfully.
    6. Run npm i
    7. Run ng serve
    On my side following these steps resolved the issue, please test them on your side and let me know of the result.
Gautam Singh
6 years, 2 months ago
Feb 12, 2026 9:51 AM
