Async request failed error
Karthik Mani
Karthik Mani asked on Mar 19, 2013 4:56 PM
Hi
I've added the Webdata grid in the ASPX (vb.net) page and here is the code snippet of the source page (HTML)
<head runat="server">
<title></title>
</head>
<body>
<div>
</div>
<asp:Button ID="Button1" runat="server" Text="Button" />
<ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="400px">
<Behaviors>
<ig:Selection CellClickAction="Row">
<AutoPostBackFlags CellSelectionChanged="True" ColumnSelectionChanged="True"
RowSelectionChanged="True" />
</ig:Selection>
<ig:RowSelectors>
</ig:RowSelectors>
<ig:Activation>
</ig:Activation>
<ig:EditingCore>
</ig:EditingCore>
</Behaviors>
</ig:WebDataGrid>
<ig:WebScriptManager ID="WebScriptManager1" runat="server">
</ig:WebScriptManager>
</form>
</body>
</html>
In the code behind, the code snippet is
Public Class personXXX
Public name As String
Public age As Int16
Public gender As String
Public status As Boolean
Public State As String
End Class
If Not Page.IsPostBack Then
WebDataGrid1.EnableDataViewState = True
BuildGrid()
Else
End If
End Sub
Private Sub BuildGrid()
Dim dataTab As New DataTable
Dim colDB As New DataColumn
Dim objRow As DataRow
WebDataGrid1.Rows.Clear()
colDB = New DataColumn("RowID", Type.GetType("System.Int16"))
dataTab.Columns.Add(colDB)
colDB = New DataColumn("Name", Type.GetType("System.String"))
colDB = New DataColumn("Age", Type.GetType("System.Int16"))
colDB = New DataColumn("Gender", Type.GetType("System.String"))
colDB = New DataColumn("Status", Type.GetType("System.Boolean"))
colDB = New DataColumn("State", Type.GetType("System.String"))
Dim per1 As New personXXX With { _
.name = "Eliza", _
.age = 27, _
.gender = "Female", _
.State = "CA", _
.status = True
Dim per2 As New personXXX With { _
.name = "Sarah", _
.age = 22, _
.State = "GA", _
.status = True
Dim per3 As New personXXX With { _
.name = "ema", _
.age = 22, _
.State = "MD", _
.status = False
Dim per4 As New personXXX With { _
.name = "rachel", _
.age = 20, _
.State = "MD", _
.status = True
Dim per6 As New personXXX With { _
.name = "jim", _
.age = 22, _
.gender = "Male", _
.State = "MD", _
.status = True
Dim per5 As New personXXX With { _
.name = "jack", _
.age = 32, _
.gender = "Male", _
.State = "CA", _
.status = True
Dim personArr As personXXX() = {New personXXX(), per1, per2, per3, per4, per5, per6}
For introw = 1 To 6
objRow = dataTab.NewRow()
objRow(0) = introw
objRow(1) = personArr(introw).name.ToString
objRow(2) = Integer.Parse(personArr(introw).age)
objRow(3) = personArr(introw).gender.ToString
objRow(4) = personArr(introw).status
objRow(5) = personArr(introw).State
dataTab.Rows.Add(objRow)
Next
WebDataGrid1.DataSource = dataTab
WebDataGrid1.DataBind()
End Sub
When I click on the checkbox in the grid, I get an error, see attached.
Any help?
    Maya Kirova
    Maya Kirova answered on Mar 13, 2013 4:31 PM
    Hello Karthik ,
    As the error suggests you need to set for the grid the DataKeyFields property in order to be able to update values in the grid.
    Generally the DataKeyFields should match the primary key of the collection you’re binding them to and should be unique for each record.
    You could set in this case the RowID as the primary key of your data table and then set that in the DataKeyFields property of the grid.
    Maya Kirova
    Developer Support Engineer II
    Maya Kirova
    Maya Kirova answered on Mar 19, 2013 4:56 PM
    Hello Karthik ,
    Maya Kirova
Karthik Mani
13 years, 4 months ago
